2019-07-04 3:57 PM
I use freertos stack overflow hook function.
So, I port the function "vApplicationStackOverflowHook" and define macro "configCHECK_FOR_STACK_OVERFLOW" set to 2.
i think hook function executed once when some task use the stack, over it's boundary.
but i see stack overflow once occurs, hook function executed continuously. (every task execution )
this is correct ?. if then, do i have to clear kind of "stack over flow flag" ?
