2016-03-31 07:00 AM
Dear all,
I would like to know if the USB battery charging detector implemented in the STM32 line works properly with USB Type-C connectors that only use USB 2.0 lines.Thank you in advance. #compatibility #bcd #type-c #usbSolved! Go to Solution.
2022-10-19 07:01 AM
Hopefully my answer can be of use to someone despite the delay. There are no issues to use battery charging detection on Type-C connectors, this detection algorithm simply works on the D+ and D- lines.
2022-10-19 07:01 AM
