STM Cube C++ Error
dhiry2k1
Posted on January 30, 2015 at 15:51
    I've been trying to use the new F4 HAL libraries for a project on the STM32F427II
I realize that this will involve a lot of C to C++ integration.
My first issue is with the two enum typedefs in
  @file    stm32f4xx_hal_def.h
typedef enum
  HAL_OK       = 0x00,
  HAL_ERROR    = 0x01,
  HAL_BUSY     = 0x02,
  HAL_TIMEOUT  = 0x03
} HAL_StatusTypeDef;
&sharpendif
  * @brief  HAL Lock structures definition
typedef enum
  HAL_UNLOCKED = 0x00,
  HAL_LOCKED   = 0x01
} HAL_LockTypeDef;
These are picked up correctly in an eclipse GCC C project but not in a C++ project.
The message is 'HAL_LockTypeDef 'does not name a type. There are about 500 such messages.
Any ideas as to how to go about either getting the C typedef to be in scope of C++, or of creating something like
&sharpifdef __cplusplus
  //enum  HAL_StatusTypeDef { HAL_OK, HAL_ERROR, HAL_BUSY, HAL_TIMEOUT } ;
 enum  class HAL_StatusTypeDef { HAL_OK, HAL_ERROR, HAL_BUSY, HAL_TIMEOUT } ;
 // typedef enum   { HAL_OK, HAL_ERROR, HAL_BUSY, HAL_TIMEOUT } HAL_StatusTypeDef;
&sharpelse
typedef enum
  HAL_OK       = 0x00,
  HAL_ERROR    = 0x01,
  HAL_BUSY     = 0x02,
  HAL_TIMEOUT  = 0x03
&sharpendif
I am not sure how to get rid of this error. I know STMCube has support of C++ but i am unable to use. Any pointer would really be appreciated.
#stm32 #- #stm32cube #c++ #c++-hal-typedef-gcc
Posted on February 02, 2015 at 08:52
Hi Dheeraj,
Which STM32CubeF4 HAL drivers version are you using ?
Please download the latest
http://www.st.com/st-web-ui/static/active/en/st_prod_software_internet/resource/technical/software/firmware/stm32cubef4.zip
version, where the HAL drivers are updated to be C++ compliant.
Heisenberg.
dhiry2k
Posted on February 03, 2015 at 15:42
Hi Heisenberg,
I am using the latest revision of HAL layer.
Still unable to get rid of this error. I am using it on Linux GCC compiler though . My compiler flags are:
-std=gnu++0x
 -g -O0 -Wall -Wl,-Map,
