2013-05-09 10:50 AM
Can any one tell me if the SAI on F429 is able to handle multi-channel duplex TDM audio? I am hoping to get 8 in 8 out simultaneously, only using the SAI.
Also what is the 10K price of F429? I am also considering $6 C6742 from TI. Will there be a discovery kit for the F429? When will it be available? #under-nda #audio #stm32f429 #sai2013-05-14 4:12 PM
Please at least tell me where I can find more info about the SAI.
2013-05-14 7:31 PM
This is a user forum. You will need to get sales and technical details via classical means, call your ST rep or FAE, and sign an NDA.
2017-05-18 1:53 AM
I have a project that i need to make a 7 microphone array. I want to use SAI with TDM, but I can't find any exemple. Did you solve your problem? Can you give me some suggestions?
