Reagarding USB HOST reading the .abs file in stm32h750
MSury.1
When I am read .text file then code works fine and reading file also fine but when I am reading the .abs and .bin file in usb host flash then I got the error reading ​file is faile ,so please suggestions me what I am do to read the .abs and .bin file stm32h750 ASAP
What are you talking about?
MSury.1
i run the code USB Host in stm32h750 .its is working fine when i read .txt file but when i am read the .abs file from pendrive then this file can not read using F_read() function. so i want to read . abs file from pendrive using stm32h750 MPU. this is my code attached
bool UsbTest_write(void)
   //Open and Created file for writing
   if(f_open(&myFile,"TEST2.TXT",FA_CREATE_ALWAYS | FA_WRITE)!=FR_OK)
      return 0;
   else
      //copy to string into the temporary variable
      sprintf(rwtext ,"Froom MANOJ");
      //write to text file
      res= f_write(&myFile,(const void *)rwtext,strlen(rwtext),&byteswritten);
      if( (res != FR_OK)|| (byteswritten==0) )
         return 0;
      f_close(&myFile);
      return 1;
void UsbTest_Read(void)
   res=f_open(&myFile, "TEST2.TXT", FA_READ);
   if (res == FR_OK)
      printf("File eTEST.TXT sucessfully opened!\n");
   size = f_size(&myFile);
   char * data = NULL;
   data = malloc(size); /* allocate memory to store image data */
   printf("File size: %d bytes\n", size);
   res = f_read(&myFile, data, (UINT) size, &bytesread);
    if (res == FR_OK){
                      printf("File successfully read!\n");
                      printf("%d bytes read\n", bytesread);
                      for (int i=0; i < bytesread; i++)
                          printf("data[%d]: 0x%x\n", i, data[i]);
                   free(data); // free allocated memory when you don't need it
                    f_close(&myFile);
