2017-07-11 08:23 AM
Posted on July 11, 2017 at 17:23
Hi Communities,
I am using STM32F745VGTX Chip for my audio playing wave file application. My problem is that playing wave file takes too much processor power, therefore I want to use DMA instead. Is there any DMA mode, therewith my wave file can be sent automatically in background with DMA?
Otherwise, please share me if any body has any supported lib of wave file on STM32F7 or another helpful lib to research.
Thanks for your help!
2017-07-12 04:59 AM
Hello
Tran.Hung.005
,As a reference that will help you, refer to the AN3126 application note.
The
Audio_playback_and_record example available under STM32CubeF7 can help you on your application.
So, if you can check how this example was implemented, it may bring you some help:
STM32Cube_FW_F7_V1.7.0\Projects\STM32746G-Discovery\Applications\Audio\Audio_playback_and_record
This example uses the wm8994 audio codec driver located at this path STM32Cube_FW_F7_V1.7.0\Drivers\BSP\Components\wm89
Best Regards
Imen
