Packages go missing when I ping .
‎2018-11-29 9:08 PM
I use stm32h7 nucleo board for ethernet communication.I use lwip raw api without rtos .
- Labels:
Ethernet
STM32H7 series
‎2018-12-20 4:36 AM
Hello @Bilge​ ,
We confirm the ping issue with the package STM32Cube_FW_H7_V1.3.0.
The problem was fixed internally and the patch will be available next year in next release of STM32CubeH7 V1.4.0.
Attached you will find the patch 'ethernetif.c' which contains the fix of the issues reported within STM32Cube_FW_H7_V1.3.0.
So, could you please re-test with the ethernetif.c attached and let us know if it solves your issue.
Kind Regards,
Imen
Imen
‎2019-02-17 8:35 AM
where is attachment?
‎2019-02-17 10:12 AM
There should be a V1.3.1 patch available in CubeMX now
‎2019-02-18 4:26 AM
Please use the latest patch STM32CubeH7 V1.3.2 available in the ST web site.
Kind Regards,
Imen
Imen
‎2019-03-05 6:27 AM
​Where can I find the patch STM32CubeH7 V1.3.2 ?
I also have the ping problem for a year.
The following site has only v1.3.0 and it still does not work..
https://www.st.com/en/embedded-software/stm32cubeh7.html#design-scroll
‎2019-03-05 8:01 AM
Hi @aJoo​ ,
Thanks for your feedback.
We are working to republish the patch STM32CubeH7 V1.3.2 on the ST web site and we need just to wait for system synchronization to activate it again.
Sorry for such inconvenience.
Kind Regards,
Imen.
Imen
‎2019-03-07 6:05 AM
The patch STM32CubeH7 V1.3.2 has just been activated on the ST web site.
Please check it https://www.st.com/en/embedded-software/stm32cubeh7.html (maybe a clean cache is needed) and let me know if this is ok for you.
Kind Regards,
Imen
Imen
‎2019-03-07 6:14 AM
> (maybe a cash refresh is needed)
I guess you ment a cache refresh ... the context is quite different.
