New to this. Downloaded the USB driver. See the driver in Control Panel/Device Manager. On the board: One solid green, one flashing green LED, LED next to the comm USB is Red and I cannot Putty into it at 115200.8.1.N.N. What am I doing wrong? Win 10
EBUKO.11
4 REPLIES 4
What board are you talking about? The NUCLEO-U575ZI-Q ?
You can open the COM port ?
You have some code loaded on the board that might connect / respond with something?
Show the code you're running
I am not actually sure what this board is called. There was an offer online on Facebook for the evaluation board to be used with a class on learning IOT integration with AWS. So I purchased that kit. I got this board and a slip of paper with QR code on it. Tried that link and video. Not much luck so far.
I have not uploaded nor downloaded anything, no code yet, of the board itself, just the USB driver.
I cannot seem to talk to the board using putty.
V/R
This one?
https://www.st.com/en/evaluation-tools/b-u585i-iot02a.html
@Imen DAHMEN​ @Amel NASRI​
Yes, that is the board. Mine differs slightly in that it says MB1551C and has some circuitry differences, but is overall the same as your pic
Ed Bukont
E2 Technical Services LLC
Art as in Engineering
Gallatin (Nashville), TN
Web: www.E2techserv.com
EMail: ed.bukont@e2techserv.com
240 417 2475
Affiliations and certifications can be found on our website
