2021-03-01 12:51 AM
Hey,
I'm programming with the STM32F415 MCU and discovered that the FLASH_CR_ERRIE declaration is missing in the CMSIS files. Is this a known issue or even intended?
If it is not intended, I assume I can safely add the missing declaration? (I never had to touch them, so I'm careful about that.)
If there is a reason why it's missing, could someone please point that out to me?
Thank you in advance and best regards,
Moritz
2021-03-09 04:55 AM
Hello @MGore ,
Thank you for your patience while I investigate this.
The FLASH_CR_ERRIE declaration will be added in the next release of STM32CubeF4 MCU package.
I can't give you any target date for the moment regarding availability of the next version.
Thank you for your contribution and for bringing this missing to our attention.
Imen
2021-03-01 07:12 AM
Hello @MGore and welcome to the STM32 Community :)
Thanks for pointing out this issue.
I am checking it internally and I will give you an update as soon as possible.
Imen
2021-03-08 02:15 AM
Hello @Imen DAHMEN,
thank you for your quick answer. Are there any updates?
Thank you for investigating and best regards,
Moritz
2021-03-09 04:55 AM
Hello @MGore ,
Imen
