Lwip MQTT can't publish a message payload more than 232 Characters
dadanugm07
Hi all, Iam trying to send a long payload message in a single buffer (const char*) to Mqtt server. Iam using Lwip Mqtt from http://www.nongnu.org/lwip/2_0_x/group__mqtt.html
It worked with payload that fewer than 232 characters. As we know the limit for mqtt payload lenght is 65536.
I tried to compare the result by publish random data (2898 characters) using mosquitto (installed in my pc), it is successfully done.
Any idea how to solve this problem?
dadanugm07
has anyone faced the same problem?
or maybe it's a new bug?
i tried it on Nucleo F7 and discovery F4, but still get the same result.
wj.anggara
Hi, open the header file with name mqtt_opts.h and edit the following sections i.e. 1024 Byte
#define MQTT_OUTPUT_RINGBUF_SIZE 1024
