Is it Compatible Marvell 88E1116R PHY chip for STM32F407 ?
KD.3
I am using STM32F407 Controller For Ethernet Application , then Marvell 88E1116R PHY Chip i want to use with STM32F407 , so is it Compatible ?
STM32 doesn't support gigabit ethernet.
KD.3
Thank you for your Answer, can i use 100MBPs or 10 MPBs with this Marvell 88E111R Phy Chip, My doubt is STM32F407 supporting MII/RMII and Marvell 88E1116R PHY Chip supporting GMII/GRMII so can i Interface??
if not possible which Phy IC i should use ??
thank you..
I don't know enough to know if GMII is backwards compatible with MII. Maybe it's like USB3 and you just have to wire it correctly. Not sure.
Any PHY that supports MII or RMII should work. You could use one used on an ST board if you wanted.
