Is it actually Possible to define multiple distinct HID joysticks on one interface?
I have Nucleo F439ZI Board
‎2023-01-23 2:57 AM
‎2023-02-10 7:15 AM
first of all, having 2 configurations won't solve your problem. As mentioned in the training, configurations are used for different "power modes" of the USB device. What you need is to have 1 device descriptor, 1 configuration descriptor and 2 interface descriptors (assuming you are going the "composite device way").
If you are using ST Middleware, you need to change interface descriptors in usbd_hid.c file, and also other functions, e. g. for reporting and enumeration of the device.
BR,
Jaroslav
‎2023-01-26 4:26 AM
Hi @VDodi.1​ ,
yes, this is possible either with multiple HID Top-level collections (if you mean under the term "interface" the logical USB interface) or with a composite device (multiple USB interfaces, but still one device = one HW interface).
BR,
Jaroslav
‎2023-01-26 7:11 PM
Yes, and here are several different examples:
https://github.com/hathach/tinyusb/tree/master/examples/device
‎2023-01-27 2:43 AM
thanks, actually i have configure my nucleo board as device and pc as host and created joystick controller interface. now i have to do multiple joystick controller with one device.
can you help how to send my data from device to pc as host ??
‎2023-01-27 2:43 AM
thank you
‎2023-01-27 6:37 AM
if you are starting with USB, I would recommend you some tutorials, e. g. this. There you can learn the general principles as well as how to send data to the host device. Or check the examples @Piranha​ posted.
If you have some specific question about sending the data, please share more details.
BR,
Jaroslav
‎2023-02-10 1:46 AM
I had check this STM32 USB training - 04 USB descriptors video. as i understand i can interface 1 device descriptor and two configuration at different time.
Can you help where should i have to edit in configuration descriptor file and other file also ??
‎2023-02-10 7:15 AM
BR,
Jaroslav
‎2023-02-14 1:42 AM
Thank You, i have created two game controller but i need different controller name to recognize my pc.
