In STM32L476G Eval board, How can i access STM's native bootloader through UART programmatically without disturbing bootpins?
SYaga.1
FBL
Hello @SYaga.1​
You can refer to the User manual Evaluation board with STM32L476ZGT6 MCU section 2.6.1 Boot options.
  • You can select STM32L476ZGT6 port BOOT0 level by the switch SW1 and by setting nBOOT1 option byte.
  • Make sure to use the latest version of bootloader V10.x because there are some limitations exist in the bootloader V9.0.
Hope this helps!
Best regards,
FBL
