I am getting FR_NOT_ENABLED error when i am trying to do File read write operation on SD card i need to know why am getting this error as my sd card is completely empty and RF_NOT_ENABLED is saying nothing but there is not enough space on logical drive.
‎2023-03-27 10:30 AM
Hello , I need to now why i am getting FR_NOT_ENABLED Error , I am getting FR_NOT_ENABLED error when i am trying to do File read write operation on SD card i need to know why am getting this error as my sd card is completely empty and RF_NOT_ENABLED is saying nothing but there is not enough space on logical drive. I am just creating a file in write append mode and reading it but it keeps giving me this FR_NOT_ENABLED Error.
How can i get rid off this error?
- Labels:
FatFS
‎2023-03-27 10:53 AM
Likely not mounted properly.
If the DISKIO layer is not working or properly validated you'll see all manner of issues at the top-level. Ensure that's working flawlessly first.
If the media is not formatted, or uses a file system that's not supported by your current build options, it will not be usable. Check the ff_conf.h settings, and that they are appropriate, ie EXFAT, etc.
ST ships an OLD version of FatFS, for large volumes this is perhaps inadvisable.
‎2023-03-27 11:13 AM
....info: i have SD + USB access running, with HAL libs, FATfs , exfat;
no problem to read 64GB sdcard or usbstick. (i dont have bigger..)
so FR_NOT_ENABLED is possibly sign for: your hardware dont work at all.
first try:
fresult = f_mount(&SDfs, (TCHAR const*)SDPath, 1); // SD card mount
result ok ?
‎2023-03-28 12:36 PM
Thanks for your response , i am getting FR_NOT_ENABLED for f_mount as well.Actually it was working fine but when i am connecting SD card to my PC it gives me virus and threat warning and any file write operation does not work and when i format it and scan it then it(File operation) works fine but each time i have to scan and format it to get rid of FR_NOT_ENABLED error. Is this error because of virus in device or is there something else i should try. I tried plain SD card FATFS sample driver code still it gives same FR_NOT_ENABLED Status for f_mount and also to f_write.
‎2023-03-28 12:42 PM
I checked for diskio is working properly or not , its working fine but i have to scan my device each time to get rid off FR_NOT_ENABLED_ERROR i am not understanding this.
