How to work with SD Card FileX and USBX MSC on stm32h573i-dk
bangjinyoung
I'd like to use both FileX and USBX MSC as SD cards on stm32h573i-dk. FileX and USBX MSC worked respectively with reference to the example. USBX MSC cannot be used when using filex_media_open().
/* USER CODE BEGIN Header */
  * @file    ux_device_msc.c
  * @author  MCD Application Team
  * @brief   USBX Device applicative file
   * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
/* USER CODE END Header */
#include "ux_device_msc.h"
#include <stdio.h>
#include "main.h"
#include "fx_stm32_sd_driver.h"
/* USER CODE END Includes */
#include "fx_api.h"
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
enum {
  SD_WRITE_FLAG = 0x01,
  SD_READ_FLAG = 0x02,
/* USER CODE END PM */
/* USER CODE BEGIN PV */
extern SD_HandleTypeDef hsd1;
extern HAL_SD_CardInfoTypeDef sd_info;
extern TX_EVENT_FLAGS_GROUP sdmmc_event;
extern FX_MEDIA sdio_disk;
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
static INT check_sd_status(uint32_t instance)
  uint32_t start = tx_time_get();
  while (tx_time_get() - start < 100) {
    if (fx_stm32_sd_get_status(instance) == 0) {
      return 0;
  return 1;
/* USER CODE END 0 */
  * @brief  USBD_STORAGE_Activate
  *         This function is called when insertion of a storage device.
  * @PAram  storage_instance: Pointer to the storage class instance.
  * @retval none
VOID USBD_STORAGE_Activate(VOID *storage_instance)
  /* USER CODE BEGIN USBD_STORAGE_Activate */
  UX_PARAMETER_NOT_USED(storage_instance);
  printf("USBD_STORAGE_Activate\n");
  /* USER CODE END USBD_STORAGE_Activate */
  return;
  * @brief  USBD_STORAGE_Deactivate
  *         This function is called when extraction of a storage device.
  * @retval none
VOID USBD_STORAGE_Deactivate(VOID *storage_instance)
  return;
  * @brief  USBD_STORAGE_Read
  *         This function is invoked to read from media.
  * @PAram  storage_instance : Pointer to the storage class instance.
  * @PAram  lun: Logical unit number is the command is directed to.
  * @PAram  data_pointer: Address of the buffer to be used for reading or writing.
  * @PAram  number_blocks: number of sectors to read/write.
  * @PAram  lba: Logical block address is the sector address to read.
  * @PAram  media_status: should be filled out exactly like the media status
  *                       callback return value.
  * @retval status
UINT USBD_STORAGE_Read(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
                       ULONG number_blocks, ULONG lba, ULONG *media_status)
  UINT status = UX_SUCCESS;
  /* USER CODE BEGIN USBD_STORAGE_Read */
  UX_PARAMETER_NOT_USED(lun);
  // UX_PARAMETER_NOT_USED(data_pointer);
  // UX_PARAMETER_NOT_USED(number_blocks);
  // UX_PARAMETER_NOT_USED(lba);
  UX_PARAMETER_NOT_USED(media_status);
  ULONG WriteFlags = 0;
  status = UX_ERROR;
  status = check_sd_status(0);
  if (status) {
    printf("SD card not ready\n");
    return status;
  /* Start the Dma write */
  status = fx_stm32_sd_read_blocks(0, (UINT *)data_pointer, lba, number_blocks);
  if(status != HAL_OK) {
    printf("HAL_SD_ReadBlocks_DMA failed\n");
  /* Wait on readflag until SD card is ready to use for new operation */
  tx_event_flags_get(&sdmmc_event,
                    SD_READ_FLAG,
                    TX_OR_CLEAR,
                    &WriteFlags,
                    TX_WAIT_FOREVER);
  /* USER CODE END USBD_STORAGE_Read */
  return status;
  * @brief  USBD_STORAGE_Write
  *         This function is invoked to write in media.
  * @retval status
UINT USBD_STORAGE_Write(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
  /* USER CODE BEGIN USBD_STORAGE_Write */
  // UX_PARAMETER_NOT_USED(lun);
  ULONG ReadFlags = 0U;
  status = UX_ERROR;
  if (status) {
    return status;
  status = fx_stm32_sd_write_blocks(0, (UINT *)data_pointer, lba, number_blocks);
    printf("HAL_SD_WriteBlocks_DMA failed\n");
  /* Wait on writeflag until SD card is ready to use for new operation */
                    SD_WRITE_FLAG,
                    TX_OR_CLEAR,
                    &ReadFlags,
                    TX_WAIT_FOREVER);
  /* USER CODE END USBD_STORAGE_Write */
  return status;
  * @brief  USBD_STORAGE_Flush
  *         This function is invoked to flush media.
  * @retval status
UINT USBD_STORAGE_Flush(VOID *storage_instance, ULONG lun, ULONG number_blocks,
  /* USER CODE BEGIN USBD_STORAGE_Flush */
  // status = UX_ERROR;
  /* USER CODE END USBD_STORAGE_Flush */
  return status;
  * @brief  USBD_STORAGE_Status
  *         This function is invoked to obtain the status of the device.
  * @PAram  media_id: is not currently used.
  * @retval status
UINT USBD_STORAGE_Status(VOID *storage_instance, ULONG lun, ULONG media_id,
  /* USER CODE BEGIN USBD_STORAGE_Status */
  UX_PARAMETER_NOT_USED(media_id);
  /* USER CODE END USBD_STORAGE_Status */
  return status;
  * @brief  USBD_STORAGE_Notification
  *         This function is invoked to obtain the notification of the device.
  * @PAram  notification_class: specifies the class of notification.
  * @PAram  media_notification: response for the notification.
  * @PAram  media_notification_length: length of the response buffer.
  * @retval status
UINT USBD_STORAGE_Notification(VOID *storage_instance, ULONG lun, ULONG media_id,
                               ULONG notification_class, UCHAR **media_notification,
                               ULONG *media_notification_length)
  /* USER CODE BEGIN USBD_STORAGE_Notification */
  UX_PARAMETER_NOT_USED(notification_class);
  UX_PARAMETER_NOT_USED(media_notification);
  UX_PARAMETER_NOT_USED(media_notification_length);
  /* USER CODE END USBD_STORAGE_Notification */
  return status;
  * @brief  USBD_STORAGE_GetMediaLastLba
  *         Get Media last LBA.
  * @PAram  none
  * @retval last lba
ULONG USBD_STORAGE_GetMediaLastLba(VOID)
  ULONG LastLba = 0U;
  /* USER CODE BEGIN USBD_STORAGE_GetMediaLastLba */
  LastLba = (ULONG)(sd_info.BlockNbr - 1);
  /* USER CODE END USBD_STORAGE_GetMediaLastLba */
  return LastLba;
  * @brief  USBD_STORAGE_GetMediaBlocklength
  *         Get Media block length.
  * @PAram  none.
  * @retval block length.
ULONG USBD_STORAGE_GetMediaBlocklength(VOID)
  ULONG MediaBlockLen = 0U;
  /* USER CODE BEGIN USBD_STORAGE_GetMediaBlocklength */
  MediaBlockLen = (ULONG) sd_info.BlockSize;
  /* USER CODE END USBD_STORAGE_GetMediaBlocklength */
  return MediaBlockLen;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
6 REPLIES 6
FBL
Hi @bangjinyoung
filex_media_open() is not a standard function in the FileX stack or ST's stack. Instead, it seems to be a custom function. Could you provide more details about the function definition?
Best regards,
FBL
AScha.3
-- you mean:   fx_media_open(..) ?
bangjinyoung
oh, i'm sorry fx_media_open() is right
void fx_app_thread_entry(ULONG thread_input)
  UINT sd_status = FX_SUCCESS;
  UINT nor_ospi_status = FX_SUCCESS;
/* USER CODE BEGIN fx_app_thread_entry 0*/
/* USER CODE END fx_app_thread_entry 0*/
/* Open the SD disk driver */
  sd_status =  fx_media_open(&sdio_disk, FX_SD_VOLUME_NAME, fx_stm32_sd_driver, (VOID *)FX_NULL, (VOID *) fx_sd_media_memory, sizeof(fx_sd_media_memory));
// /* Check the media open sd_status */
  if (sd_status != FX_SUCCESS)
    /* USER CODE BEGIN SD DRIVER get info error */
    while(1);
    /* USER CODE END SD DRIVER get info error */
  /* Open the OCTO-SPI NOR driver */
 nor_ospi_status =  fx_media_open(&nor_ospi_flash_disk, FX_NOR_OSPI_VOLUME_NAME, fx_stm32_levelx_nor_driver, (VOID *)LX_NOR_OSPI_DRIVER_ID, (VOID *) fx_nor_ospi_media_memory, sizeof(fx_nor_ospi_media_memory));
/* Check the media open nor_ospi_status */
  if (nor_ospi_status != FX_SUCCESS)
    /* USER CODE BEGIN OCTO-SPI NOR open error */
    while(1);
    /* USER CODE END OCTO-SPI NOR open error */
/* USER CODE BEGIN fx_app_thread_entry 1*/
  UINT        status;
  CHAR        entry_name[256];
  UINT        attributes;
  ULONG       size;
  UINT        year;
  UINT        month;
  UINT        day;
  UINT        hour;
  UINT        minute;
  UINT        second;
  /* Get the next directory entry in the default directory with full information. */
  printf("nor flash disk directory:\n");
  do {
    status = fx_directory_next_full_entry_find(&nor_ospi_flash_disk, entry_name, &attributes, &size,
                                            &year, &month, &day,
                                            &hour, &minute, &second);
    if (status == FX_SUCCESS) {
      /* Process the directory entry. */
      printf("File: %s, Size: %lu, Date: %02u/%02u/%04u, Time: %02u:%02u:%02u\n",
             entry_name, size, day, month, year, hour, minute, second);
  } while (status == FX_SUCCESS);
  printf("sd disk directory:\n");
  do {
    status = fx_directory_next_full_entry_find(&sdio_disk, entry_name, &attributes, &size,
  status = fx_media_close(&sdio_disk);
  if (status) {
    printf("Failed to close sd disk: %x\n", status);
/* USER CODE END fx_app_thread_entry 1*/
oh, i'm sorry. fx_media_open () is correct. I added the code below.
oh, i'm sorry. fx_media_open () is correct. I added the code below~
One sorry is enough.. :)
In your code i see open for sd-card and nor-flash - so what about the usb problem ?
