How to use the VREFINT as Vref for adc?
Ilyas
Hi, I'm using stm32l432kb and I want to use the internal reference voltage Vrefint as reference voltage for the AD converter. Is this possible?
Guru
No, VREFINT is not available as a VREF source. It's not a particularly accurate reference anyway. And it's below the allowable range.
You can use VREFBUF, or VDDA. (Can't use VREFBUF as VREF+ is tied to VDDA.)
Guru
No it's designed for you to measure and dereference the reported values vs the range of the ADC. Using a voltage that is "known"
Basically ratios, so elementary school type math involved.
