2023-10-10 06:53 AM
Hi, I'm using stm32l432kb and I want to use the internal reference voltage Vrefint as reference voltage for the AD converter. Is this possible?
2023-10-10 07:19 AM - edited 2023-10-10 07:21 AM
No, VREFINT is not available as a VREF source. It's not a particularly accurate reference anyway. And it's below the allowable range.
You can use VREFBUF, or VDDA. (Can't use VREFBUF as VREF+ is tied to VDDA.)
2023-10-10 07:27 AM
No it's designed for you to measure and dereference the reported values vs the range of the ADC. Using a voltage that is "known"
Basically ratios, so elementary school type math involved.
