How to create lwip project using stm32h747-disco
YZhen.4
I would like to ask you guys how to use the stm32h747-disco development board to create a project, hoping to get advice
4 REPLIES 4
YZhen.4
​There is also no lwip project in the official routine
KDJEM.1
Hello @YZhen.4​  and welcome to the Community :),
I advise you, when you configurated the LwIP project, to get inspired form the steps described in this FAQ: How to create project for STM32H7 with Ethernet and LwIP stack working. This FAQ will help you to configure your project in STM32CubeMX .
Also, you can get started with the example provided here STM32H7-LwIP-Examples. This example supported the STM32H747-Disco board.
Kaouthar
YZhen.4
Thank you very much for your answer. I configured it according to FAQ: How to create project for STM32H7 with Ethernet and LwIP stack working, but the Lwip initialization cannot pass. I will try the example you said, thank you again.
YZhen.4
Hello @KDJEM.1 Have you generated the corresponding project of Keil? I found that there are many differences between the configuration of Keil project and CubeIDE
