How to correctly config interrupts priority (using HAL)?
areify
Hi there.
I'm trying to set up my NVIC but I'm not able to understand how they work.
I'm using two timers, GPIO and UART. I used the function HAL_NVIC_SetPriority and set the next priorities:
TIM 1 -> (Preempt: 0, sub: 0)
TIM2 -> (Preempt: 1, sub: 0)
UART -> (Preempt: 2, sub: 0)
GPIO -> (Preempt: 3, sub: 0)
I don't know if this is correct, but it's working properly. My problem comes when, using 3 channels of TIM1 at same time, I have nested interrupts. This made my interrupts not to jump at specified time.
My question is simple... how can I set the priority of the output compare interrupts of my timer?
I think that I'm not understanding this format of priority (preempt, sub) as well I need...
Thank you in advance
0 REPLIES 0
