Help for STM32 F767Zi as USB host for mass storage
‎2023-03-12 12:00 PM
Hi, I am using STM32 F767Zi and tried this tutorial to use it as an USB host ***. I followed the steps but I always end up in Use Case _USER_CLASS_ACTIVE. I tried different USB devices but it's always the same. Does anyone have an idea how I can solve the problem or how I can look for the problem? Thank you!
Post link deleted to adhere community guidelines.
- Labels:
STM32F7 Series
USB
‎2023-03-13 11:03 AM
Thank you very much for your help!! I found the solution to my problem at the end here: https://community.st.com/s/question/0D53W000026BISCSA4/stm32f746discovery-usb-host-fs-msc-not-working-application-state-never-go-to-state-application-ready
‎2023-03-12 1:14 PM
Have ControllersTech support you?
You have a NUCLEO-F767ZI board OR you have a STM32F767I chip on some other board?
Perhaps look a available USB MSC HOST code in theCubeF7 repository for NUCLEO, DISCO, EVAL boards?
STM32Cube_FW_F7_V1.15.0\Projects\STM32F767ZI-Nucleo\Applications\USB_Host\MSC_Standalone
‎2023-03-12 4:03 PM
Thank you very much for your answer!
No I just used the tutorial of ControllersTech to set up the project.
I have the Nucleo-F767ZI board.
I am so sorry I have to ask, but I can not figure it out; how do I implement the sample code from CubeF7 into Cube Ide?
‎2023-03-12 6:07 PM
Just use the CubeIDE feature, "import example project". Read the fine CubeIDE manual for details. Make sure to update CubeIDE and the CubeFW_F7 package.
