File transfer through Ethernet
‎2019-03-11 4:55 AM
Hi all,
How to transfer file through server to target board using Ethernet ?
I'm using STM32F429 Nucleo-144 board, currently done with STM32F4xx Webserver Demo
( Based on the lwIP TCP/IP stack ).
Based on this server demo how transfer file server to target and process on target ?
- Labels:
Ethernet
STM32F4 Series
‎2019-03-11 5:41 AM
One typically uses HTTP or FTP. You'd need to have somewhere to store the data, writing to internal flash is a bit slow. Do you have an SD card wired up?
‎2019-03-11 5:45 AM
I have pendrive with OTG.
my usage is process audio file Using STM32F429 nucleo-144. If store it in pendrive how its possible ?
‎2019-03-20 10:08 AM
I'm using stm32f429 nucleo 144.
I want to connect board with PC using Ethernet with static IP.
My application should transfer the PC file data to the target board through Ethernet.
Using latest STM32Cube_FW_F4_V1.24.0 how its possible ?
Which protocol suites this type of file transfer?
Is it possible with this example application - /home/STM32Cube_FW_F4_V1.24.0/Projects/STM32F429ZI-Nucleo/Applications/LwIP/LwIP_HTTP_Server_Netconn_RTOS
How to view target board data on debugger memory window ?(Just sharing text information)
PC side and target board side what are the application should alive for this process?
