Failed to open earlier version *.ico in Cube V4.10.0.
Microstar
Posted on September 02, 2015 at 05:05
Upgrade today, but it stall when open the *.ico file created by V4.9.0.
#stm32cube #bug
4 REPLIES 4
Nesrine M_O
Lead II
Posted on September 02, 2015 at 11:44
Hi Tension,
I tested the case but I didn't face your problem: the *.ioc file created by CUBEMX V4.9.0 is correctly opened by the V4.10.0 and I succeeded to generate the code.
So please try to check your *.ioc file.
-Syrine-
thomfischer
Posted on September 02, 2015 at 21:50
I have the same problem , CubeMx stalls , attached my .ioc file
Win 7 64 bit java version ''1.7.0_75''
________________
Attachments :
template.ioc : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htl8&d=%2Fa%2F0X0000000aWa%2FtvwCAaKfdQi1lMk.sPuDu6GDB5V3Aw3ikmK2AI85L1Y&asPdf=false
Nesrine M_O
Lead II
Posted on September 03, 2015 at 18:57
Hi thomas.004,
It seems to be a modified parameter which is causing the load issue
In your case, replace RCC_PLLP_DIV4 by RCC_PLLSAIP_DIV4 at line 1328
-Syrine –
thomfischer
Posted on September 03, 2015 at 21:02
Hi Syrine,
thanks , i changed the line and the project loaded.
