DS1307 unable to set time
arun singh
Posted on June 01, 2017 at 09:17
Hey guys, this is my first post in this forum.
So i am trying to interface ds1307 tiny rtc module with stm32f401 nucleo via i2c1 but unable to set time to it. I am getting the uptime of rtc but whenever I am trying to set time,nothing happens.
 here is some of my code:
/* i2c related----------------------------------------*/
char slave_address_lcd = 0x4E;
char slave_address_clock = 0xD0;
int chkflag = 0;
void check_i2c_status (void);
/* clock related -----------------------------------------*/
uint8_t sec_rec, min_rec;
void clock_init(void);
struct time_t {
uint8_t seconds;
uint8_t minutes;
uint8_t hour;
uint8_t day;
uint8_t date;
uint8_t month;
uint8_t year;
}time;
void set_time (uint8_t sec, uint8_t min, uint8_t hr, uint8_t d,uint8_t dt, uint8_t mon, uint8_t yr);
void get_time (void);
uint8_t cnvt_to_bin (uint8_t data);
uint8_t cnvt_to_dec (uint8_t data);
uint8_t high = 0;
uint8_t low = 0;
high = data/10;
low = (data)-(high * 10);
return (high<<4) | low;
return ((data & 0x0f) + ((data>>4)&0x0f)*10);
uint8_t data[7], addr = 0x00;
data[0] = cnvt_to_bin (sec);
data[1] = cnvt_to_bin (min);
data[2] = cnvt_to_bin (hr);
data[3] = cnvt_to_bin (d);
data[4] = cnvt_to_bin (dt);
data[5] = cnvt_to_bin (mon);
data[6] = cnvt_to_bin (yr);
HAL_I2C_Master_Transmit (&hi2c1, slave_address_clock, &addr, 1, 100);
HAL_I2C_Master_Transmit (&hi2c1, slave_address_clock, data, 7, 100);
void clock_init (void)
uint8_t data[2];
data[0] = 0x00; // go to address 0x00
data[1] = 0x00; // write 0 to that address thus starting rtc
HAL_I2C_Master_Transmit (&hi2c1, slave_address_clock, data, 2, 100);
HAL_I2C_Master_Receive (&hi2c1, slave_address_clock|0x01, data, 7, 100);
time.seconds = cnvt_to_dec (data[0]);
time.minutes = cnvt_to_dec (data[1]);
time.hour = cnvt_to_dec (data[2]);
time.day = cnvt_to_dec (data[3]);
time.date = cnvt_to_dec (data[4]);
time.month = cnvt_to_dec (data[5]);
time.year = cnvt_to_dec (data[6]);
void StartDefaultTask(void const * argument)
/* USER CODE BEGIN 5 */
/* Infinite loop */
for(;;)
get_time ();
sprintf (lcd_hour, '%02u', time.hour);
lcd_send_cmd (0x80);
lcd_send_string (lcd_hour);
sprintf (lcd_min, '%02u', time.minutes);
lcd_send_cmd (0x83);
lcd_send_string(lcd_min);
sprintf (lcd_sec, '%02u', time.seconds);
lcd_send_cmd (0x86);
lcd_send_string(lcd_sec);
osDelay(100);
/* USER CODE END 5 */
main ()
clock_init ();
set_time (25, 50, 20, 2, 31, 05, 17);
#i2c #stm32f4 #i2c-ds1307 #rtos
0 REPLIES 0
