Did _callback function runs inside interrupt scope?
LOliv
I'am new on using CubeMX and HAL functions. I would like to know if interrupt callback functions, that can be use for execute some code after ISR, are executed from inside interruption scope.
I'm asking that because as a programing good pratices, code executed within interrupt routine should be as short as possible to avoid latency and nested interrupts. So, if _callback runs within interruption it should be short either.
Thanks in advance.
S.Ma
Principal
Callbacks are mainly interrupts user hooks of the corresponding ISR.
Keep callbacks content brief.
If HAL callbacks requires time optimisation, go for LL (low layer)
S.Ma
Principal
LOliv
Thanks for the answer
