CubeMX USB Host MSC FATFS
Options
2019-10-19 3:18 AM
I generate code for STM32F105RBT using cubemx(5.30) and USB Host MSC FATFS setting, now its work about connect and disconnect flash stick but alwayse Appli_state is in APPLICATION_IDLE,
.is something should i do to for APPLICATION_READY??
while (1)
/* USER CODE END WHILE */
MX_USB_HOST_Process();
/* USER CODE BEGIN 3 */
if(Appli_state==APPLICATION_READY)
else if(Appli_state==APPLICATION_IDLE)
else if(Appli_state==APPLICATION_START)
else if(Appli_state==APPLICATION_DISCONNECT)
Labels:
- Labels:
STM32Cube MCU Packages
STM32F1 Series
USB
0 REPLIES 0
