Controlling STM32Cube HAL drivers
Jay Vincet
Posted on December 19, 2016 at 23:16
I have defined all my pins using STM32Cube but I do not see a control that lets me turn off HAL drivers. Could someone tell me how to turn off driver code development?
Thanks,
John Hite
#stm32cube
Oliver Beirne
Posted on December 20, 2016 at 03:34
Hi
jayvincet
I&39ve moved this post to
https://community.st.com/community/stm32-community/stm32-forum?sr=search&ampsearchId=fcc9c16e-a260-42e5-a32b-cd58456b6124&ampsearchIndex=0
where product-related questions should be posted so if you have any more in the future drop them here as well .
Oli
Imen.D
Posted on December 20, 2016 at 19:13
Dear
Vincet.Jay
You can use STM32CubeMX tool with the peripherals that you want which help you to initialize peripherals, build and generate your project with initialization C code.This allow you to choose the microcontroller, select the peripherals you want and map them to pins graphically.
Take a look to these reference for more detail about STM32CubeMX tool:
Moreover, you can start from working example under STM32CubeXX firmware package, in the context of understanding the tools and you find the needed include parts for your project. Then, you can modify the application depending on your needs.
The reference Manual and datasheet related to your device will be your support for more clarification about the HAL driver and configuration the pins.
I recommend you to start with 'Getting started' manuals which allow you to go step by step to start your project.
Best Regards
-Imen-
Imen
