2022-01-19 12:50 PM
Can someone give me a config.h file for the H735 Discovery kit ?
Cannot get past the compile errors...
There is nothing in my config file
2022-01-20 1:52 AM
which 'config.h' are you referring to, could you please share the compile errors you are facing?
2022-01-20 12:24 PM
@Haithem Rahmani
Can you try to compile it ?
you will see the errors..
then you will see you need to populate the config file,
then you can send it to me...
Are you able to compile it for the H735 Discovery kit ?
