2023-02-21 08:47 PM
When checked on telnet that there was no response from the ST web page, when requested for header
Is there any issue in using ST website for getting the real time?
2023-02-23 07:29 AM
http://www.st.com still responds to Firefox browser GET requests. It does not with wget or curl.
It's worth mimicking the header fields of a working GET request in the embedded application.
Or just point to an HTTP server which is less picky.
2023-02-23 07:43 PM
Thanks for the quick reply. Are you suggesting to use a different url other than http://www.st.com?
2023-02-27 10:18 PM
We observe that the http://www.st.com was responding until 6th February and there after failing to respond. Due to this all our field devices are offline. Can this be reverted so that we can correct this?
