Activating USB core clock disables the Ethernet link
Options
‎2012-12-11 3:14 AM
Posted on December 11, 2012 at 12:14
I am working on USB and Ethernet integration with USART. My ethernet Application is running perfectly and i am inserting code for USB into it. I noticed when i enable USB core clock, The ethernet link disconnects and my LCD shows '' Network Cable is unplugged'' I dont know why this is happening ? Anyone had the same issue? I am using STM32F207 USB and Lwip Libraries. with STM3220G-EVAL Board. Thanks, Dheeraj #connectivity-usb #ethernet-interface #stm32
Options
‎2012-12-11 8:16 AM
Posted on December 11, 2012 at 17:16
I've not heard of an issue.
You should perhaps look over the schematic and pin utilization to see if there is an interfacing conflict. Consider also if the board implements a MII or RMII interface, and where it derives it's clock.
Options
‎2013-01-27 10:01 PM
Posted on January 28, 2013 at 07:01Thanks clive ... yes there was pin conflict :)
