USART3 (on Arduino connector CN14) troubles on stm32u5 iot eval board BU585IIO2A
‎2022-03-24 2:24 AM
i'm using the stm32u5 iot eval board BU585IIO2A and want to use USART3 on Arduino connector CN14
i successfully got the PWM working on PIN7 of CN14 but i fail to get anything sent / received on UASRT3 (Pins 1 and 2 of CN14)
are there any hints / samples how to get this working ?
thx, peter
STM32U5 series
UART-USART
‎2022-03-25 6:24 AM
>> we must still have some differences in our project settings - how could we find them ?
I have sent you my main.c file. Can't do more.
Just check that your stm32u5xx_hal_msp.c file assigns the USART3 to PD8/PD9 instead of default PC10/PC11.
Share your project if you feel like.
‎2022-03-25 6:32 AM
i checked that anc actually it does NOT.
see the code below :
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
if(huart->Instance==USART1)
/* USER CODE BEGIN USART1_MspInit 0 */
/* USER CODE END USART1_MspInit 0 */
/** Initializes the peripherals clock
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
/* Peripheral clock enable */
__HAL_RCC_USART1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**USART1 GPIO Configuration
PA10 ------> USART1_RX
PA9 ------> USART1_TX
GPIO_InitStruct.Pin = T_VCP_RX_Pin|T_VCP_TX_Pin;
GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
/* USART1 interrupt Init */
HAL_NVIC_SetPriority(USART1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(USART1_IRQn);
/* USER CODE BEGIN USART1_MspInit 1 */
/* USER CODE END USART1_MspInit 1 */
else if(huart->Instance==USART3)
/* USER CODE BEGIN USART3_MspInit 0 */
/* USER CODE END USART3_MspInit 0 */
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART3;
PeriphClkInit.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
Error_Handler();
__HAL_RCC_USART3_CLK_ENABLE();
/**USART3 GPIO Configuration
PA7 ------> USART3_TX
PA5 ------> USART3_RX
GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_5;
GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
/* USART3 interrupt Init */
HAL_NVIC_SetPriority(USART3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(USART3_IRQn);
/* USER CODE BEGIN USART3_MspInit 1 */
/* USER CODE END USART3_MspInit 1 */
do you think, that's the problem ?
do i have to set up this specifically in the .ioc file ?
thx again, mike - i think now we are on the right track ... ;)
‎2022-03-25 6:37 AM
Yes, that should be the problem...
In the .ioc you have to assign it to PD8/PD9,
and you should end up with that:
__HAL_RCC_GPIOD_CLK_ENABLE();
PD8 ------> USART3_TX
PD9 ------> USART3_RX
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
‎2022-03-25 6:42 AM
i checked and fixed that : (sorry, i was not aware of the necessary re-assignment :( )
anyway, you've made my day !
with that adaption now your main.c work, as well so i think, it's also going to work with my application, now
thx, again, mike : great support !
peter
- « Previous
- 1
- 2
- Next »
