stm32 ADC scann mdoe
‎2024-01-20 1:37 AM
In the ADC scan mode in STM32 microcontrollers, the digitized value of all input channels is dumped into ADCx->DR. Is there a register or flags to find out which ADC channel the data currently in the ADCx->DR register
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc) { if(hadc->Instance == ADC1) { uint16_t adc_data; // Read the converted data from the ADC data register adc_data = ADC1->DR; //I don't know which ADC channel this data is related to // Process the ADC data as needed // ... } } void ADC_Init() { ADC_ChannelConfTypeDef sConfig; hadc.Instance = ADC1; hadc.Init.ScanConvMode = ENABLE; hadc.Init.ContinuousConvMode = ENABLE; hadc.Init.NbrOfConversion = 2; // Number of channels to convert hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.NbrOfDiscConversion = 1; if (HAL_ADC_Init(&hadc) != HAL_OK) { Error_Handler(); } // Configure the ADC channels to be converted sConfig.Channel = ADC_CHANNEL_0; sConfig.Rank = 1; sConfig.SamplingTime = ADC_SAMPLETIME_13CYCLES_5; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { Error_Handler(); } sConfig.Channel = ADC_CHANNEL_1; sConfig.Rank = 2; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { Error_Handler(); } }
STM32F1 Series
‎2024-01-20 1:53 AM - edited ‎2024-01-20 1:55 AM
You set up the sequence, the ADC is converting - right ?
So you should know , whats the first channel/result and whats the next - and so on.
Results are coming just in the sequence order, you set up - so if you set sequence to convert
ch1 - ch3 - ch4 the results are for ch1 - ch3 - ch4 - ch1 - ch3 - ch4 .... . Thats it.
‎2024-01-21 5:23 AM
Yes, I know the order of the channels, but suppose for some reason ADC interrupt does not run (for example, due to the occurrence of a simultaneous interrupt with a higher priority). After that, we may not be able to distinguish which channel the current data belongs to
‎2024-01-21 5:56 AM - edited ‎2024-01-21 6:15 AM
No, still the next value you get/read , is the next in the sequence.
You always do only one conversion, then read the result.
So give high enough priority to the adc interrupt , to be sure, you can keep the speed, you want.
Or do the (adc sequence) -> [data array] with the DMA, then you cannot have problems about loosing a result (and the "position" in the sequence). For using the adc at hi speed and/or big array of results you should use the DMA anyway.
ed.:
from F1 rm :
So if using the sequence scan mode, you need to use dma anyway and so always sequence is stored correct .
‎2024-01-21 6:30 AM
Or use the injected conversion ->
-> have 4 register for corresponding conversion :
