STLINK-v3 does not support connection under reset?
Pavel A.
Pardon me if this is a red herring... the forum is hard to search.
IIRC someone (Clive?) mentioned recently that STLINK-v3 does not support connection under reset. Is it so? Then, a standalone ST-LINKv3 or built in some eval.boards?
I'm asking because going to try something on my H753 eval board that may require "hard" recovery via the debugger connection.
-- pa
4 REPLIES 4
I think I mentioned it the other day, but there was a conversation that proceeded that.
Yesterday
https://community.st.com/s/question/0D50X0000BRZL5NSQX/nucleoh745-stlink-utility-can-not-connect-to-target
Where the commentary came from, warning from command line tool
https://community.st.com/s/question/0D50X0000B7ZD0HSQW/resolve-connect-under-reset-is-available-only-on-stlinkv2-for-stlinkv3set
ST-LINK Utility V4.5.0\ST-LINK_CLI.exe
[%s]: Connect under Reset is available only on ST-LINK/V2!
[%s]: Hardware Reset is available only on ST-LINK/V2!
#ElephantInTheRoom
Thank you.
And Keil? What says Keil debugger? I only have 5.27, not latest.
-- pa
Not sure, will check when I have an opportunity.
The EVAL board does have BOOT pin switches on it.
