2025-06-20 5:16 AM
Could you please help me with my Nucleo-H753ZI board power issue? I would greatly appreciate your assistance.
Earlier, the nucleo-h753zi board worked normally when I applied external power from a power supply at 9 volts.
When I applied power using a 9-volt battery, overcurrent occurred and the U12 component overheated. Could you please advise me on how to handle this situation?
Other than the power supply, nothing else was connected - only GND and the external power supply pin were connected. Even without external power, when I connect USB, the overcurrent LED still comes on.
I would be very grateful for your guidance on resolving this issue.
I think the board has probably crossed the point of no return.
2025-06-20 7:27 AM - edited 2025-06-20 7:29 AM
https://community.st.com/t5/stm32-mcus-boards-and-hardware/nucleo-h753zi-overcurrent/m-p/700629
PS:
Also:
2025-06-23 8:48 AM
Can you be more specific about how/where specifically you are applying external power? Have you changed any jumper settings? A picture of the setup may help.
