No target found error
Options
‎2020-09-27 7:37 AM
I am using STM32 controller (STM32L475VC) for our project. I am getting error as "NO TARGET FOUND" when
- I am trying to debug through ST-Link V2 or
- Trying to access the controller for Erase/Program with STM32CubeProgrammer
I have done following steps to erase & program the controller
- Hold Reset pin low momentarily while connecting to target with STM32CubeProgrammer over SWD interface using ST-Link. Not able to access the target.
- Tried to connect to target using "Under Reset" mode over SWD interface using ST-Link. Not able to access the target.
- Put controller in USB DFU bootloder mode and able to erase & reprogram the controller successfully over USB interface using STM32CubeProgrammer. But again when I tried to debug/erase/program the controller over SWD interface using ST-link, I am getting same error as "NO TARGET FOUND"
Kindly, provide support for this issue.
Sanjay
Labels:
- Labels:
ST-Link
STM32CubeProgrammer
STM32L4 series
Options
‎2020-09-27 9:07 AM
Has it every worked? custom board?
Pins not wired properly, buffers on ST-LINK/V2 not powered properly, see pin 1/2
Conflicting with other devices connected to SWDIO/SWCLK
Options
‎2020-09-27 9:47 PM
Yes it was working Custom board. Pins are wired properly. SWDIO/SWCLK pin are not conflicting with others
