2026-06-08 10:06 AM
Hi
I would like to generate a PWM signal on a pin on the board of the EVALSPIN32G0A1 EVB, but no signal is being generated. I tried doing it onthe pins of J5 (the hall conctors pins) and on the pins of J2 but no ignal is generated there. i tried checking any manual change on them by accesssing the ODR registers (after setting the ODER registers to be regular outputs) but no change on the pins. can someone help me to find the reason for it please ?
