In "en.stm32cubeh7_v1-11-0" we can't find demo project for NUCLEO-H753ZI board
RongShengWang
1. I bought NUCLEO-H753ZI board, but we can't find any firmware demo project for the NUCLEO-H753ZI board in downloaded "en.stm32cubeh7_v1-11-0" (Its directory "NUCLEO-H753ZI" is empty).
    We need the ADC firmware demo projects for NUCLEO-H753ZI board.
    Where we can find them?
2. NUCLEO-H753ZI ADC does not accept the analog negative signal inputs. Is there any STM32H7 dev board(s) accepting the analog negative signal inputs?
   Thanks,
1 REPLY 1
krotti42
For the ADC demo projects you can use the same one which are for the NUCLEO-H743ZI board. Those projects should be also fully compatible for the NUCLEO-H753ZI board.
+ All projects available under Projects\NUCLEO-H743ZI are fully compatible with NUCLEO-H753ZI board.
+ For crypto feature available on NUCLEO-H753ZI board, examples under Projects\STM32H743I-EVAL\Examples\CRYP can be used as reference.
Source (Projects/NUCLEO-H753ZI/readme.txt) in the STM32cubeH7 Github repository
