Hi, i am facing a very annoying problem, i am using STM32H755ZI-Q 144 NUCLEO KIT, when i connect it get STLink, but not receiving chip, can anyone help me, thanks thank you very much
NGUYEN-VAN NHI
4 REPLIES 4
What does the error message actually say? Target Not Found?
Did you get the LDO/SMPS settings wrong?
Try power cycling the board with BOOT0 HIGH, see if it will connect, and then erase the broken user code.​
NGUYEN-VAN NHI
Yes, the real error is "Target not found". I am trying to try the way you suggested. Thank you.
Andrew Neil
Please don't put the entire post in the Title - see:
https://community.st.com/s/article/How-to-Post
Limit the title to ~ 70 characters.
#KeepTitleShort
Oh my bad mistake, thanks for the reminder.
