Getting Started with my STM32F3Discovery, need help I am stuck
Justin1
Posted on July 01, 2016 at 04:20
 I am looking to fully ramp into the STM32 series for work and have no experience in ST yet. I purchased -
  • (1) STM32F3Discovery (STM32F303)
  • (1) ST-LINK/V2
My sole goal is to get code generated, compiled and deployed to an STMicro32 product, get my feet wet to prep for later uses in product.
After my research it appears that the only way to JTAG is through manual dang wire-by-wire connection, from the ST-LINK's STM32 port to the Discovery platform - yikes!!! My sole goal here was to get my feet wet and not much further for the moment. Wire-by-wire, that is WAY more than dipping your toes in, yikes!!
Question/Request/Plea: How do I correctly dip my feet in, get an STMicro32 platform and deploy code to it, then debugging and stepping the code one instruction at a time? With a pre-packaged solution, cables and plugs, no wire-by-wire :(!!
If this is not possible and wire-by-wire is required, ok fine. But - ewwww / yikes :(
 Justin
#stm32f3discovery #st-link
Posted on July 01, 2016 at 04:32
The DISCO has a built in ST-LINK, you just plug in the mini-USB cable, load the drivers, and download directly from IAR, Keil, or with the ST-LINK Utilities.
Walid FTITI_O
Senior II
Posted on July 01, 2016 at 12:29
Hi reina.justin,
There is user manuals to help you go step by step in your start with our STM32 platforms and built you own project successfully.
You find in the
http://www.st.com/en/evaluation-tools/stm32f3discovery.html
, user manual for ''Getting started with software and firmware environments for STM32F3DISCOVERY kit'' which are
http://www.st.com/content/ccc/resource/technical/document/user_manual/be/b3/12/61/3f/d7/45/67/DM00062662.pdf/files/DM00062662.pdf/jcr:content/translations/en.DM00062662.pdf
and
http://www.st.com/content/ccc/resource/technical/document/user_manual/group0/d0/f7/45/d7/3b/96/47/b3/DM00285842/files/DM00285842.pdf/jcr:content/translations/en.DM00285842.pdf
. You find , in addition , STM32F3DISCOVERY kit user manual with schematics in the
http://www.st.com/content/ccc/resource/technical/document/user_manual/8a/56/97/63/8d/56/41/73/DM00063382.pdf/files/DM00063382.pdf/jcr:content/translations/en.DM00063382.pdf
Once you have your hardware and software environment ready, you could start to run our project examples in
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef3.html
Welcome.
Keep the good work
-Hannibal-
