Dimension of STM32F746IEK6
2023-05-04 8:27 PM
what's the dimension of STM32F746IEK6. Especially for thickness, is there any tolerance ?
Documentation
STM32F7 Series
2023-05-10 6:51 AM
Hi @Cchen.1 ,
Maybe the problem is due to the accuracy of the measurement instrument you used to measure the dimension. For that, I advise you to refer to this post.
Kaouthar
2023-05-05 12:34 AM
Hello @Cchen.1 ,
You can fin the STM32F746IEK6 MCU dimension in the datasheet and precisely in 6.7 UFBGA 176+25, 10 x 10 x 0.65 mm ultra thin-pitch ball grid array package information Section.
Also, you can refer to table Table 120. in the datasheet to find the tolerance value for the different dimensions.
Kaouthar
2023-05-05 12:51 AM
Thanks Kaouthar, According to table 120, The maximum thickness of A should be 0.6mm while we measured several pieces all excess 0.6mm. is that normal?
2023-05-05 1:15 AM
Hi @Cchen.1 ,
The A value should be between 0.460mm and 0.600mm.
To check this issue, can you please share the chip photo of your STM32F746IEK6 MCU.
Kaouthar
2023-05-05 3:17 AM
hi Kaouthar
here's the picture. btw just curious A1 is 0.05-0.11 , A2 is 0.4-0.5 ,A = A1+A2 , then A=(0.05+0.4-0.11+0.5)=0.45 -0.61 which is against 0.46mm-0.6mm,
2023-05-10 6:51 AM
Hi @Cchen.1 ,
Kaouthar
