Cannot change settings on STM32 ST-Link Utility
Jonathan Camilleri_2
Posted on January 09, 2018 at 17:42
I am trying to change the settings on the STM32 ST-Link Utility, jhowever, the software seems to be freezing. I also installed it on another computer and it still doesn't seem to work. The problem is shown in the attached screen shot. Any suggestions as to why?
#st-link-v2 #stm32-st-link-utility #st-link-utility-problem
20 REPLIES 20
Posted on April 15, 2018 at 11:34
Check if the target chip has all pins properly soldered (especially grounds and supply, including the analog ones) and that there is no short between the signals and any other neighbouring pin or track.
Use a short cable between STLink and the target (<10cm).
