X-NUCLEO-NFC03A1 14443A emulation code
‎2022-01-20 1:30 AM
The example code for X-NUCLEO-NFC03A1 does not have a few methods mentioned in the headers, including st25r95SetACState(). This makes the 14443A emulation code not useful. Can you please provide the working example? Thank you
‎2022-01-20 5:04 AM
thanks for using ST25R95/CR95HF product. Card Emulation source code is not part of the X-CUBE-NFC3 v2.1.0 but I will provide it to you in private.
Feel free to share more details about your card emulation application to help us to provide appropriate support.
Rgds
BT
‎2022-01-20 5:04 AM
Rgds
BT
‎2024-10-31 1:33 AM
Hi BT,
I also need the code for card emulation. Can you provide me with a copy of it?
