Will the irq_cmd bit in ST25RU3993 go high after execution of the each direct command mentioned in Table 4 of the datasheet?
Design Team
When we sent a direct command "Hop to main frequency", after the execution of the direct command we did not get any interrupt on the SPI and irq_cmd was low. When we tried the same experiment using "Automatic power supply level setting" as the direct command, after execution the irq_cmd was high.
Bart Herse
Senior II
Dear Design Team,
could you please share the contents of register 0x35 and 0x36.
This would help us understanding the issue further.
Cheers,
B
