2020-08-11 5:54 AM
I've observed that output level on both antenna port is lower than is specified in datasheet. I've checked it on two eval boards. Below results:
For internal PA: (output level set/ measured level/ detector voltage
For external PA:
In both cases output level is lower by 7-8 dBm that expected. Any suggestion?
Best Regards, Michał
2020-08-12 6:34 AM
Problem probably solved and was in my spectrum analyzer malfunction.
Michal
2020-08-12 6:34 AM
Michal
