Read data memory of ST25DV04K from elatec TWN4 NFC reader
toamsm
Anyone having experience of reading data memory of ST25DV04K (ISO 15693) using a elatec TWN4 NFC reader?
Regards Tomas
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Brian TIDAL
ST25DV04K is an ISO 15693 / NFC Forum Type 5 tag. It supports the standard Read Single Block command to read memory blocks. The Elatec transponder matrix claims for the support of NFC Forum Type 5 tag for various TWN4 devices. I would suggest to contact the technical support of the TWN4 manufacturer to get more information on how to perform NFC Forum T5T Read Single Block command from their firmware and their environment.
Rgds
BT
1 REPLY 1
Brian TIDAL
Rgds
BT
