2023-10-11 5:38 AM
pls suggest a example for reader/writer/formatter for NFC03A1
are there any writer example code for RPi similar to poller example ?
https://community.st.com/t5/st25-nfc-rfid-tags-and-readers/x-cube-nfc3-for-stm32cube/td-p/591339
i didnot find the source for the same..
i did notice X-CUBE-NFC3 , Ver 2.1.0 is available
https://www.st.com/en/embedded-software/x-cube-nfc3.html
2024-01-02 8:59 AM
as of today, Linux demos for Raspberry Pi have been officially released only for ST25R3911B and for ST25R3916 NFC reader devices. An unofficial package for ST25R95 can be found in Solved: CR95HF - Linux RFAL demo - STMicroelectronics Community.
Regarding NDEF vs. raw proprietary data, NDEF has the advantage of being a standard format.
Rgds
BT
2023-10-11 7:36 AM
which tag technology do you plan to use : T2T, T3T, T4T or T5T? Do you plan to write NDEF formatted message or raw proprietary data?
Rgds
BT
2023-10-17 10:37 AM
Sorry for the delayed response Brian... i was OOO.
we will be using T2T and T5T (14443A and 15693 tags).
for now we will go with NDEF formatted messages.. i am not sure of raw proprietary data
do you see any advantages between them ?
2024-01-02 8:59 AM
Rgds
BT
