2020-10-25 10:00 AM
Hi
I would like to know if the ST25DV64K tag is going operate with a regular SO14443-A reader? I have already tested the tag against a Samsung S10 phone running the ST's app and is working perfectly.
Best Regards
Gilberto
2020-10-26 07:58 AM
Hello Gilberto,
If you need and I2C interface and ISO144443-A product you have the M24SR64K product available at the link below :
the Datasheet is available here :
https://www.st.com/resource/en/datasheet/m24sr64-y.pdf
Best Regards,
BB
2020-10-26 12:58 AM
Hello Gilberto,
The ST25DV64K tag is going to operate well with a regular ISO14443-A reader, with respect to initialization phase ( Anticollision, RATS, Select Application, Select File commands …)
Best Regards,
BB
2020-10-26 07:23 AM
Hello Gilberto,
sorry I read too fast your question
ST25DV64K is not compatible with an ISO14443-A reader because it is ISO15693 compliant.
If you need an ISO14443-A compatible tag you have ST25TA64K in ST portfolio.
Best Regards,
BB
2020-10-26 07:32 AM
2020-10-26 07:58 AM
Hello Gilberto,
Best Regards,
BB
