I bought ST25RU3993-EVAL. I want to be able to read RFID UHF tags from 10m. Which antena I need to buy. Can you send me distributor and name of such antenna.
JJońs.1
Peter BENSCH
There might be the Poynting Patch A0025 antenna, which is also mentioned in a demo video on Youtube.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Hi Peter,
I decided to buy Poynting PUCK-1 LTE SISO 6dBi because Poynting Patch A0025 is directional, but I need omnidirectional.
Please tell me what kind of settings I should do, to make the biggest range.
Pozdrawiam,
Janusz Jonski
Peter BENSCH
As you can seen in the video it is possible to reach the distance of 13 meters - using the directional antenna. Using an omnidirectional antenna significantly reduces the possible distance due to the physics of energy distribution, so I doubt you can get the 10 meters you want.
Please get in contact with your distributor or our OLS support team to get additional answers to this question.
/Peter
