2022-01-10 12:45 AM
Is FTM only available to use with development kits ? I cannot use FTM with mobile application. Is there any guide ?
2022-10-13 12:07 AM
In ST25SDK, you can use the method readMailboxMessage() of the Class ST25DVTag.
hasHostPutMsg(true) can be used to check the bit indicating that the MCU( connected to the ST25DVTag) has put a message into the Mailbox.
2023-02-22 06:51 PM
stsw-st001中邮箱打开无读�?�界�?�没有�??应怎么回事
