How to launch properly application to read NFC tag with an NFC03A1 nucleo attached to a NUCLEO F091RC ?
KBens.1
I am trying to read some NFC tag with a X-NUCLEO-NFC03A1 attached to a NUCLEO F091RC board. I am a beginner into those technology, so basically I was trying to load the sample "NFC Detect " from the package "X-CUBE-NFC3" wich can be found on ST official website to understand how to use NFC stuff. The problem is, I tried to build the project on the STM32 IDE Cube, and it worked fine, but i can't read anything on the NFC NUcleo's antenna after running the programm.
I suppose there are problems of initialisation , but i have no idea how to debug this.
Thanks you for your time,
Best Regards,
Karim
31 REPLIES 31
Brian TIDAL
your nfcvDevice variable is not initialized... the proper way is to used nfcDevice that is initialized thanks to rfalNfcGetActiveDevice( &nfcDevice );
The proper call to demoNfcv is:
demoNfcv( &nfcDevice->dev.nfcv );
See demo.c.
Rgds
BT
Thanks a lot, it worked fine ! :)
Best regards,
Karim
