How to increase the range of CR95HF receiver on a custom PCB?
GU.1
I am using the following configuration.
protocol :- ISO/IEC 14443 Type A tags
TimerW value :- 0x58
Modulation Index and Receiver Gain :- 0xD0
Reader Antenna Dimensions
L=28 mm
W =28 mm
No of turns=3 turns
Find attached diagram for designator reference
C11=180pF
C12=180pF
C2=180pF
I am also using an Low pass EMI filter
L01=L02="Part number=742792042"
C01=C02=180pf
I have tried fine tuning with various capacitor combinations.
I got slightly better range of 1.3 cm when replacing C11 and C12 with 1nF capacitor.
otherwise the range is around 0.9 cm.
For Tag i am using Keyfobs tokken type tag.
Please help me understand how to obtain greater range?
Is it by changing the modulation and gain configuration?/tag used?/capacitance values? or should i redesign the antenna.?
I designed a small antenna as per edesign suite to fit CR95hF and antenna in my 30mm x 30mm PCB such that the circuits and components are in the centre of the PCB while Antenna is on the outer circling the circuit.
Kindly help me out.
Gokulan
Henry Crane
Hi Gokula,
thanks for sharing your new designs.
Keeping copper ground plane as shield around components is generally recommended, particularly arounbf cristal oscillator and tuning circuit. Don't know you design rules like clearance around tracks, but it is possible without living too much dead copper, you may try to restore a bit grounf plan on design with components out of the antenna. you may start ground plan on a line B1-R1 (to leave 2mm minimum between groung plan and antenna, up to the PCB border close to the crystal.
For designs with components inside the antenna, you may just put some ground plan to shield the crystal oscillator and CR95HF.
see pictures below, ground plan suggestion in yellow.
best regards,
Henry Crane
14 REPLIES 14
Brian TIDAL
H Gokulan,
many parameters impact the read range:
  • tag antenna
  • reader antenna and matching circuit
  • etc.
On my X-NUCLEO-NFC03A1 with the X-CUBE-NFC3 firmware, depending on the tag, I can achieve the following read range: 3.2 cm for ISO14443 tags and up to 5.2 cm (for some tags with very good antennas). The X-CUBE-NFC3 firmware uses Modulation Index and Receiver Gain = 0xD3. Most of the tags being used for those read range tests are ID-1 size tag (aka credit card size).
As a first step, I would suggest to measure the read range with the keyfob token on a X-NUCLEO-NFC03A1 as a reference.
See also https://community.st.com/s/question/0D50X00009XkWUk/cr95hf-antenna-design-query for some tips about the antenna design.
Rgds
BT
GU.1
I measured the same on a ST25R3911B-DISCO board and got about 4 cm read range with the keyfob token RFID tag.
I don't have the X-NUCLEO-NFC03A1 Nucleo to test the same. Hope the above reading gives you an idea.
GU.1
I also tried using Modulation Index and Receiver Gain = 0xD3 on my PCB, but the range was further reduced only.
Ulysses HERNIOSUS
Hi Gokulan,
your antenna is not really big. Not sure if you can achieve major improvements. Best would be if you could provide data for some known tag to have a common reference. I could think of: Banking cards (typically ID1 or half of ID1 size) or CLOUD-ST25TA which may have a similar form factor as your keyfob. What is in your possession what we could use as reference?
Regards, Ulysses
GU.1
I have uploaded a 3D PDF of my PCB file for you reference, Also i have tested with CLOUD-ST25TA it gave slightly better range of about 13-14 mm compared to the keyfob's less than 10mm.
Also find attached a link of RFID fob's i am using
https://www.digikey.com/en/products/detail/mikroelektronika/MIKROE-2256/8564410
Brian TIDAL
on my X-NUCLEO-NFC03A1 (34x47mm/4 turns/0.8ohm~1120nH antenna), I reach a 30-31mm read range with the CLOUD-ST25TA02KB.
Rgds
BT
Hi Gokulan,
side note: I tried to check the mentioned MIKROE-2256 fob. The available data sheet from disties is just a marketing flyer. And on mikroe.com I did not even find this product. Do you have more information on this product?
Regards, Ulysses
Hi Ulysses,
The reason my antenna is not big is because my client want it in a very small foam factor, this is for an wardrobe lock application. they gave me a maximum PCB size of 30*30 mm. Kindly let me know if i can re-route the PCB with a different antenna to get much higher reception with the same 30 x 30 mm size.
Gokulan
Hi Gokulan,
to me (being a software engineers) increasing from 28x28 to 30x30 I would not expect a major improvement. As Brian has performed also some tests below on X-NUCLEO-NFC03 which give 30mm as opposed to your 13mm we think that improvement could be possible. He is discussing internally with people being more experienced with antennas on possible reasons and what you could try.
In general there are always two possible reasons why the read range is limited:
  1. The output power is not sufficient to power the tag -> lower impedance / change antenna
  2. The tag is powered and answering but the reader does not receive/decode the tag signal. -> Inspect noise and the receive path
To differentiate 1. and 2. you can use an oscilloscope probe where you connect the ground wire to the tip (building a loop) and put it in free air close to the tag antenna. You should be able to see/trigger on the reader modulation (WUPA in OOK) and some 90us later the tag modulation (subcarrier of 848kHz imposed on the 13.56MHz).
Regards, Ulysses
P.S. I assume you are currently using your antenna in free air. Please beware in a wardrobe lock you may have metal parts close by which may have a strong negative effect on your antenna.
